#114267 - 31/08/2002 22:39 Automatic linux user login help
muzza
Could anyone point me in the right direction to have a linux box boot and automatically log in as a default user (luser?).
The assignment I have requires that we create a package that can be installed on a 486 w/16M & 500M Hdd; startup and automatically log in as a default user; attach to a windows server and run a session through rdesktop.
Any hints are greatly appreciated.
#114268 - 31/08/2002 23:05 Re: Automatic linux user login help [Re: muzza]
You probably don't need to log in as a user, which is fortunate, since it's bad design and probably not possible without a lot of hacking.
Take a look at how your Linux machine starts up gdm/xdm (probably via init and it's config file, inittab). It should give you some ideas about how to implement this.
Basically, your system will start an X server and then run rdesktop on top of it. No login will be needed, since, effectively, root will be telling it what to do, but doing it as a different user.
#114269 - 01/09/2002 03:29 Re: Automatic linux user login help [Re: wfaulk]
muzza
I think I understand, Thanks
I'll let you know how things go.
#114270 - 01/09/2002 13:16 Re: Automatic linux user login help [Re: muzza]
There is a Howto on creating a kiosk that went into stuff like that. You can find it at tldp.org .
