#13386 - 10/08/2000 00:13
Sync Error
This is the first sync error I got (I'm syncing directly from CD to Mk2 via ethernet). The error was:
The synchronisation process failed during stage 5:||Error 80070057: The paramet
Can't see more than this on my screen. I'll try again. That doesn't really disturb me too much since this is the first error and the last CD which has enough place on the Mk2.
TeeMcBee Go my Mk2! # 080000143
TeeMcBee [orange]Mk2, # 080000143, 40+30 GB, Tuner, Peugeot stalk hookup</font color=orange>
#13387 - 10/08/2000 01:16
Re: Sync Error
[Re: teemcbee]
I'm not totally sure it the above error was a problem with emplode or the Mk2. I could also be that my WinNT had problems with the CD-Rom as it was not acessible any more after the sync-error. I had to reboot an after that everything went fine again.
#13388 - 10/08/2000 02:35
Re: Sync Error
[Re: teemcbee]
I've also had (this morning) my first sync error for a looooonnggg time, over serial: The synchronisation process failed during stage 5:||Error 0xFFFFFF92 As well as the fact that the failure occurred, there's even a bug in the error message as there is obviously some extraneous character in there represented by the two vertical bars! One of the few remaining Mk1 owners... #00015
#13389 - 10/08/2000 03:57
Re: Sync Error
[Re: schofiel]
Additionally I have to say that I run Beta12c - I'll upgrade tomorrow - when I have the (hopefully right) nullmodem cable with me.
#13390 - 10/08/2000 04:06
Re: Sync Error
[Re: teemcbee]
This is a windows error, it looks like emplode made an API call with an incorrect parameter value.
From winapi.h
// // MessageId: E_INVALIDARG // // MessageText: // // One or more arguments are invalid // #define E_INVALIDARG _HRESULT_TYPEDEF_(0x80070057L)
__ Unit serial number 47 (was 330 in the queue)...
#13391 - 10/08/2000 04:44
Re: Sync Error
[Re: schofiel]
Loc: Meije, Netherlands
Yep, the same error here, after an integrety check over USB: and the error message in emplode has the same two funny characters. After CtrlAltDel (without killing anything) W98 found new hardware and wanted to search for drivers.
Prior to this failing, I aborted a sync after 30 minutes: no display on player (black);emplode telling that it was controlling the disk; the disk (in the player) active (ratling); nothing else happening.
Also I found the integrety very check slow and and timed it next time around: 7 minutes before the progess bar started to show; after 16 inutes the progress bar was at 100%; one minute later restart of the player; everything OK
Henno mk2 6 nr 6 this was on consumer 1.0
Henno
mk2 [orange]6 [/orange]nr 6
#13392 - 10/08/2000 07:48
Re: Sync Error
[Re: Henno]
Loc: NRW, Germany
Had a different error message with the same bars, and I had a scroll bar at the bottom of the message window! (I think this was when I was playing on one of our Win2000 machines, but I'm not certain). It appears that the two non-printing characters (black vertical bars) are probably meant to be the carrage return that wraps the error message. Remember empeg changed the error messages so that you can now copy and paste them. You can scroll along and read the rest of the error message. I'm sure this will be fixed soon.
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 6GB blue)
#13393 - 10/08/2000 08:42
Re: Sync Error
[Re: Derek]
Forgot about that: will try it next time. next time ???
Henno mk2 6 nr 6
Henno
#13394 - 10/08/2000 09:04
Re: Sync Error
[Re: Derek]
The bars are because the read-only edit box doesn't display LF characters properly. They have to be CRLF pairs. Some of the error messages weren't formatted correctly. I've fixed it now.
The fix should be in a maintenance release at some point.
As other people have said, you can just scroll along to see the rest of the message.
#13396 - 10/08/2000 22:25
Re: Sync Error
But on one out of about 20 CD's it's a good rate  TeeMcBee Got my Mk2! # 080000143
#13397 - 15/08/2000 23:12
Re: Sync Error - Stage 10?
[Re: teemcbee]
Loc: BC
First sync error ever here as well (see attached).
Apparently during Stage 10. emplode let me continue, but the unit sat on the 'synchronizing' display for some time, not moving.
I let it be for a good 10 minutes and it eventually came to its senses. My recently-uploaded tracks all seem to work.
-------------------- Reg #57xx, Ser #080000141, Rec'd Aug.11/00
MK2 #141 12GB Queue #5723 (SOLD)
MK2a 30GB + grn + tuner + blk empeg case
#13398 - 15/08/2000 23:58
[Re: Fogduck]
Stage 10 is part of the download after the upload. If it fails at this point, your music has still been successfully uploaded. If it does this again, try to capture a log file, and email it to bugs@empeg.com. It'll probably end up on my desk, and I'll look into it. Roger - not necessarily speaking for empegEdited by Roger on 16/8/00 07:59 AM.
