#144950 - 21/02/2003 23:07 Shell command to report power status
TheAmigo
I'm guessing that probably nobody will find these usefull, but here they are just in case.
Two simple progs: ac and dc. The ac program reads /proc/empeg_power and returns true if the empeg is on ac and false if it's on dc. The dc prog is the other way 'round.
Why? It's less CPU and RAM overhead than grep "Power)" /proc_empeg_power | grep -c AC.
142889-acdc.zip (46 downloads)
--The Amigo
#144951 - 22/02/2003 06:40 Re: Shell command to report power status [Re: TheAmigo]
Ah. But if you use open/read/close instead of the buffered IO functions it should save you a little more RAM
Using return instead of exit probably should shave a little more off the binary as well.
Sorry, being picky
- Trevor
