#14643 - 20/08/2000 18:00 Another Sync Problem
dWarf
Loc: Oakville, ON, CA
I receive the following error everytime I try to use emplode, whether through Ethernet or serial:
The download process failed during stage 7:
Error 80004005: Unspecified error
I've rebooted both my PC and the Empeg several times and re-imaged twice (consumer 1.0) with no effect. At the bottom of the emplode log is the following line; it's seems to be the only one that indicates a problem.
00:18:12.212 EmplodeDoc.cpp(668) : I [00f9] Found out of bounds tag in file - rebuild the database please!
I previously had it fail a couple times during stage 5 but it recovered with no problems in both cases. The player seems to operate without any problems with the music I've already uploaded, I just can't connect to put on more.
Any ideas?
Thanks,
Steve
MKII 080000075 - 18G, green
MKII 080000075 - 18G, [green]green[/green]
#14644 - 21/08/2000 05:40 Re: Another Sync Problem [Re: dWarf]
Does it keep doing this? Can you actually get a successful sync now, or is it completely wedged?
#14645 - 21/08/2000 07:31 Re: Another Sync Problem [Re: Roger]
dWarf
I still get the error everytime; Ethernet or serial.
#14646 - 21/08/2000 08:27 Re: Another Sync Problem [Re: dWarf]
OK, email bugs@empeg.com, and we'll see what we can do about getting you an early cut of the version of emplode that fixes this.
