#146841 - 04/03/2003 15:20 Emphatic Install questions
djdrock
I am running Hijack beta 11, and having difficulty with Emphatic. Here are my questions...
1. Will it work with hijack beta 11?
2. I edited the .bat file and changed the ip to the correct ip address for my player. I then added the [output] notify=1 to the config.ini file. I then double clicked the .bat file and this is what I got: Does this look correct?
Installing emphatic...
C:\Documents and Settings\djdrock\Desktop\emphatic-1.10>ftp -s:install-emphatic.
ftp 192.168.1.2
Connected to 192.168.1.2.
220 Connected.
User (192.168.1.2:(none)):
230 Login okay.
ftp> quote site rw
200 Okay.
ftp> cd /usr/local/bin
431 No such directory.
ftp> bin
200 Okay.
ftp> put emphatic
200 Okay.
150 Opening data connection.
226 Okay.
ftp: 348756 bytes sent in 1.21Seconds 287.99Kbytes/sec.
ftp> quote site chmod 755 emphatic
200 Okay.
ftp> quote site ro
200 Okay.
ftp> quit
221 Happy Fishing.
C:\Documents and Settings\djdrock\Desktop\emphatic-1.10>pause
Press any key to continue . . .
3. I rebooted my player, accessed the hijack menu by holding down the volume button, but there is no menu for Emhpatic. Any ideas?
4. There is no [Startup] section ReserveCache=48 in my config.ini. Do I need to manually add it? Here is a copy of my config.ini.
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=empegcar
[User Info]
Email=djdrock@blah.com
Phone=317-123-3456
Name=David Eaton
[Network]
Gateway=0.0.0.0
Netmask=255.255.255.0
IPAddress=192.168.1.2
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[display]
visual_names=1
caching=1
[synchronise]
seq_num=59
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[hush]
hushpercent=20
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[aux]
source=
title=
artist=
[output]
notify=1
Thanks for your help!!!
1993 MR2 MK2a 32gb. 1991 NSX unfortunately with and IPOD.
#146842 - 04/03/2003 15:35 Re: Emphatic Install questions [Re: djdrock]
justinlarsen
Loc: Petaluma, CA
firts off you will need to create or make a /usr/local/bin folder as the player dosnt have this on there by defualt. I assume this is just how tony (ynot) has his player setup.
The easier solution woudl be to ftp in and make it.
also you im not too sure about beta 11 but you shouldnt have to add the [Startup] section ReserveCache=48
You will need to have the latest hijack version installed, then read the readme that comes with the program about adding a new line to your config.ini file to have hijack start the program.
---- Justin Larsen
#146843 - 04/03/2003 16:00 Re: Emphatic Install questions [Re: djdrock]
That is a non sequitur. Perhaps you mean... Empeg software version beta 11, with hijack?
If you are running beta 11 empeg software, please upgrade to beta 13 as it fixes some egregious bugs in beta 11. Then upgrade to the latest Hijack. You need both in place before using Emphatic.
#146844 - 04/03/2003 17:14 Re: Emphatic Install questions [Re: tfabris]
djdrock
You are correct...hijack 11??? I now have software beta 13 installed and upgraded to hijack 320.
I used my ftp program to make the directory usr/local/bin, and then installed emphatic there. I verified this after the install in the ftp program, and the emphatic file (340KB) is there. I added the ;@EXEC_ONCE /usr/local/bin/emphatic line to my config.ini file. The [output] notify=1 is also there. I synchronized the player. Here is my config.ini file now:
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=empegcar
[User Info]
Phone=317-111-1111
Name=David Eaton
[Network]
Gateway=0.0.0.0
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[display]
visual_names=1
caching=1
[synchronise]
seq_num=60
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
count=0
count=0
count=0
count=0
[hush]
hushpercent=20
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[aux]
source=
title=
artist=
[output]
notify=1
When I enter hijack, there still is no emphatic menu?
Still, any ideas?
Thanks!!!
#146845 - 04/03/2003 17:18 Re: Emphatic Install questions [Re: djdrock]
The EXEC command must be in the [hijack] section, not at the end of the file like you have it. If there is no [hijack] section, make one.
#146846 - 04/03/2003 17:19 Re: Emphatic Install questions [Re: djdrock]
Run the install script again now that /usr/local/bin is there. The install script has a command which will make the emphatic binary executable. The command is:
chmod 755 /usr/local/bin/emphatic
I'm not sure this is the problem, but since the script failed first, and now you've moved the binary manually, I'm thinking it's not an executable file. The above command will make it so.
If this is not the problem, then please post a log of what shows up when you boot your player. That should give me an idea of what's going wrong.
Edit: Bart is right. Try his suggestion first.
Edited by yn0t_ (04/03/2003 17:19)
#146847 - 04/03/2003 17:32 Re: Emphatic Install questions [Re: tonyc]
djdrock
The text that is in my current "install-emphatic.ftp" is:
quote site rw
cd /usr/local/bin
bin
put emphatic
quote site ro
quit
I re-ran the .bat file...it is installing, but it still will not come up in hijack.
Is it the emplode.log file you want to take a look at?
Thanks again!!!
#146848 - 04/03/2003 17:59 Re: Emphatic Install questions [Re: djdrock]
If it's still not coming up in hijack then please connect the serial cable to your computer, connect to it with hyperterminal, and post the log of messages that come up when you boot up your empeg. The FAQ should have details on how to do this.
#146849 - 04/03/2003 18:22 Re: Emphatic Install questions [Re: tonyc]
djdrock
Here is the file:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
Processor: Intel StrongAR
empeg-car player (hardware revision 9, serial number 30102312)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x98378
empeg display initi
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:0
8
Partition check:
RAMDISK: ext2 filesystem found at
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#146850 - 04/03/2003 18:35 Re: Emphatic Install questions [Re: djdrock]
Okay you followed tfabris' suggestion and moved this line:
to the [hijack] section of your config.ini, right? Can you post your config.ini?
#146851 - 04/03/2003 19:04 Re: Emphatic Install questions [Re: tonyc]
djdrock
I did move the file to the hijack area of the config.ini, but I had to create it. I based it on a post I had seen. I was able to, just once, see the emphatic menu in hijack. When I pressed it, it did nothing, and I had to resyncronize. It has not shown up since. Here is my config.ini:
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=empegcar
[User Info]
Phone=317-123-4567Name=David Eaton
[Network]
Gateway=0.0.0.0
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[display]
visual_names=1
caching=1
[synchronise]
seq_num=66
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
count=0
count=0
count=0
count=0
[hush]
hushpercent=20
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=1
[aux]
source=
title=
artist=
[output]
notify=1
[hijack]
Thanks again!!!
#146852 - 04/03/2003 19:31 Re: Emphatic Install questions [Re: djdrock]
There's no sign of Hijack attempting to run emphatic with a hijack_exec command in the serial log you posted, and there's no output from emphatic telling me what's going on.
You've stumped me.
#146853 - 04/03/2003 19:39 Re: Emphatic Install questions [Re: tonyc]
djdrock
I just tried to reinstall it again...here is what I got:
ftp 192.168.1.2
220 Connected.
230 Login okay.
ftp> quote site rw
200 Okay.
250 "/usr/local/bin" directory changed
ftp> bin
200 Okay.
ftp> put emphatic
200 Okay.
550 Failed.
200 Okay.
ftp> quote site ro
200 Okay.
ftp> quit
221 Happy Fishing.
Notice, it does say "failed" in the text above. Could it have something to do with the command you posted earlier (chmod 755 /usr/local/bin/emphatic) and that the text that is in my current "install-emphatic.ftp" is:
quote site rw
cd /usr/local/bin
bin
put emphatic
quote site ro
quit
Is the only file that should be in the usr/local/bin area "emphatic"?
Thanks again!
#146854 - 04/03/2003 19:44 Re: Emphatic Install questions [Re: djdrock]
No, what the script is doing is correct. The "failed" happens when it's trying to put the emphatic binary... Which makes me think that, when you ran the script, the emphatic binary is in use (running.) Either that, or your disk is full... Is there anything interesting on the serial console when you try running the batch file? And can you make sure that your serial log on bootup still looks the same as it did before?
#146855 - 04/03/2003 19:50 Re: Emphatic Install questions [Re: tonyc]
djdrock
when you say "Is there anything interesting on the serial console when you try running the batch file", what do you mean? Is the serial log the info from hyperterminal?
#146856 - 04/03/2003 19:51 Re: Emphatic Install questions [Re: djdrock]
Yah, in Hyperterminal.
#146857 - 04/03/2003 20:01 Re: Emphatic Install questions [Re: tonyc]
djdrock
Here it is again:
e000 v1.04
Copying kernel...
l.
empeg display initi
8
Partition check:
Mounting proc
player
Vcb: 0x4086d000
#146858 - 04/03/2003 20:03 Re: Emphatic Install questions [Re: djdrock]
No, I mean leave hyperterminal connected and try the install program. You should see stuff happening in the hyperterminal window, probably some Hijack messages like "remounting drive / read-write" or similar.
This is my last try tonight... I'm almost out of ideas.
#146859 - 04/03/2003 20:16 Re: Emphatic Install questions [Re: tonyc]
djdrock
Here is what hyperterminal said:
hijack: Remounting read-write: /
hijack: Remounting read-write: /drive0
hijack: Remounting read-only: /
hijack: Remounting read-only: /drive0
#146860 - 04/03/2003 20:18 Re: Emphatic Install questions [Re: djdrock]
Okay that doesn't help me. I was expecting error messages from the Hijack ftpd when you see "failed" in the FTP window. Hopefully someone else looking at this (probably someone who isn't as tired as I am tonight) will have better ideas.
#146861 - 04/03/2003 20:24 Re: Emphatic Install questions [Re: tonyc]
djdrock
I saw on this post http://empeg.comms.net/php/showthreaded.php?Cat=&Board=hackers_prog&Number=143626&page=&view=&sb=&o=
that you mention making sure emphatic is executalble by this command:
chmod +x /usr/local/bin/emphatic
Should I try this, and if so, what is the best way?
And, is it normal for me to not have a hijack section in my .ini? I had to make one.
Thanks again!
#146862 - 04/03/2003 20:26 Re: Emphatic Install questions [Re: djdrock]
The chmod 755 is doing the same thing as chmod +x. Can you do the following from the shell prompt, after quitting out of the player app from Hyperterminal:
ls -l /usr/local/bin/emphatic
Edited by yn0t_ (04/03/2003 20:26)
#146863 - 04/03/2003 20:29 Re: Emphatic Install questions [Re: tonyc]
djdrock
Shell prompt? Do you mean from a command prompt? And if so, could you tell me specifically what to do. I am sure you can tell by now, that I have no programming skills. :-)
#146864 - 04/03/2003 20:32 Re: Emphatic Install questions [Re: djdrock]
Well, don't let the terminology confuse you, just do what I asked. In the hyperterminal window, quit out of the player app by typing "q" then enter. You should be at a shell prompt which is the Linux equivalent of the command prompt. Then just type:
And you should see a directory listing which I was hoping would give me more info on what's happening here.
But I'm more confused by the fact that Hijack isn't complaining about the file not being there, so really, I'm just grasping at straws here.
#146865 - 04/03/2003 20:38 Re: Emphatic Install questions [Re: tonyc]
djdrock
I am so sorry to be a pain, but when I type q in hyperterminal, nothing comes up. Any ideas??
#146866 - 04/03/2003 20:38 Re: Emphatic Install questions [Re: djdrock]
Type q then hit the "enter" key.
#146867 - 04/03/2003 20:41 Re: Emphatic Install questions [Re: tonyc]
djdrock
i did, it does absolutely nothing but have a flashing cursor. It does say that i am connected on the bottom left of hyperterminal.
#146868 - 04/03/2003 20:46 Re: Emphatic Install questions [Re: djdrock]
Allright well then I am sorry to say that I'm 100% out of ideas for now.
In the future, I am hoping there will be a more automatic installation process for user applications, but until then, this manual, pain-in-the-ass process is what we've got, and, sadly, it's sometimes beyond the capabilities of those without Linux experience.
#146869 - 04/03/2003 20:47 Re: Emphatic Install questions [Re: tonyc]
djdrock
understandable. I appreciate what you have done so far. If anyone else wants to chime in with any ideas, please do so.
Thanks!!!
#146870 - 04/03/2003 20:48 Re: Emphatic Install questions [Re: djdrock]
lectric
Loc: New Orleans, LA
Be sure you are using 115200 N81 as your settings in hyperterm.
