#150816 - 25/03/2003 20:26 No Hard Disk Found
Gleep
Loc: Iowa
I just received my 2nd RioCar that I purchased on Ebay. Upon hooking it up, I get No Hard Disk Found. After reading the FAQ I tried my Power Supply that works fine with my first one, Nope still not found. This RioCar came with only a 10gig drive and I have a 20gig on hand so I decided to replace the 10gig with a 20gig. I loaded the drive formatting utility with the new drive and still get drive not found. Below is the output from hyperterminal. Any help would be greatly appreciated.
Kelly
ircomm_tty: virtual tty driver for IrC
If there is anyone present who wants to upgrade the flash, let them speak now,r version 4.27 with no serial options enabled
or forever hold their peace...it seems not. Let fly the Penguins of Linux! UART
ttyS01 at 0xf8050000
e000 v1.04is a SA110
Copying kernel...
Calling linux kernel...02 at 0xf8030000 (irq =
Uncompressing Linux..................................... done, booting the kernes 206f6972 'rio '
empeg display initialised.
l.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versixer initialised
empeg dsp initialised
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.ort initialised 0089/88c1 (save to d0004000).
empeg-car player (hardware revision 9, serial number 40104282)d
empeg power-pic driver initialis
Command line: mem=16m
Calibrating delay loop... 207.67 BogoMIPSlized: 16 RAM disks of 4096K size
Probing primary interface...
hda: TOSH
hda: TOSHIBA MK2016GAP, ATA DISK drive
Page cache hash table entries: 409
smc9194.c:v0.12 03/06/9
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7
a
Partition check:
hda
Starting kswapd v 1.5 hda1
or forever h
empeg remote control/panel button initialised.guins of Linux!
e000 v1.04
Copying kernel.
hda: TOSHIBA MK2016GAP, 19077MB w/0kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:b
a
Partition check:
hda: [PTBL] [2584/240/63] hda1
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount fs on 03:05
#150817 - 25/03/2003 20:33 Re: No Hard Disk Found [Re: Gleep]
The log you posted appears to be for the 20GB drive, which is working just fine. But it needs to have the Empeg diskbuilder software run on it before it will work in the player. The FAQ probably describes this, along with how to repair the kitchen sink.
#150818 - 25/03/2003 20:40 Re: No Hard Disk Found [Re: Gleep]
SE_Sport_Driver
Check the FAQ at RioCar.org
btw: why doesn't "www" work for empeg.comms.net and riocar.org?
#150819 - 25/03/2003 21:10 Re: No Hard Disk Found [Re: mlord]
Gleep
Loc: Iowa
Thanks Mark! I re-ran the load of the disk formatter and it worked this time. I had switched the hard-drive cable from using the middle connector to the end connector. The 20gig now is fine and the old 10gig works too, so it is a BAD cable. Is this a standard cable or will I need to get a replacement from Rio?
Thanks again,
Kelly
#150820 - 25/03/2003 21:12 Re: No Hard Disk Found [Re: Gleep]
The latter.
