#151600 - 30/03/2003 15:58 MKl Display Problems
Laura
Loc: Greenhills, Ohio
I seem to be having a small problem with my MKl display today. When I turned it on, I noticed a small black square in the lower right hand corner, enough that it cuts off part of the bootup Tux and the time remaining on a song.
Any ideas what it could be? The rest of the display is fine and it was fine a few days ago when I last played it.
Laura
MKI #017/90
whatever
#151601 - 30/03/2003 16:35 Re: MKl Display Problems [Re: Laura]
Weird. Has the Empeg been knocked or dropped recently? The VFD fill nipple is near that spot.
- Trevor
#151602 - 30/03/2003 16:52 Re: MKl Display Problems [Re: tman]
Laura
I moved it to another location but I was very careful with it and never dropped or knocked it hard. If it was the fill nipple I would think the whole display would be dead. I guess I'll have to open it up and take a look for anything it might be.
Laura
MKI #017/90
whatever
#151603 - 30/03/2003 17:52 Re: MKl Display Problems [Re: tman]
Laura
Problem solved. It turned out to be a small piece of black plastic or film that was originally attached to the back of the lens that had dropped down into the corner of the display. I went ahead and replaced the lens and all is well.
I do wonder what that piece is for.
Laura
MKI #017/90
whatever
#151604 - 30/03/2003 18:03 Re: MKl Display Problems [Re: Laura]
Infrared filter, so sunlight doesn't set off the IR. You might want to glue it back in place somehow. Not sure how (to make it look good).
#151605 - 30/03/2003 18:44 Re: MKl Display Problems [Re: tfabris]
Laura
Thanks for letting me know. Moving it around must have loosened it but I have a few spare lenses. Maybe Rob would know of a good way to attach it back on.
Laura
MKI #017/90
whatever
#151606 - 31/03/2003 04:16 Re: MKl Display Problems [Re: Laura]
We used a dab of superglue.
#151607 - 31/03/2003 04:23 Re: MKl Display Problems [Re: rob]
Laura
Thank you Rob. I will give that a try.
Laura
MKI #017/90
whatever
