#20677 - 18/10/2000 04:47 random decoding errors?
smu
Loc: Germany (Ruhrgebiet)
Hi.
With some of my tracks, I get problems while playing them on the empeg. Here is whatīs happening at some times (but not always):
During playback, I get a seemingly random mixture of the original sound plus artefacts that range from low pitched "bing" (imagine a high pitched bing (as from hitting two metal pieces (small pipes or something) against each other, than lengthen that sound to about 4 or 5 times its original length, lowering the pitch by the same rate, e.g. get a 5 seconds 200Hz signal out of a 1 second 1000Hz signal) to sharp edges (the same thing you get when turning on/off the empeg while the amp is already on). Sometimes, the empeg reboots and starts playing the same song again, which is a much better behavior than the old 1.0 software that simply crashed (hanging only to be re-vitalized by powercycling). After the reboot, the empeg usually plays the song completely, sometimes even without (audible) artefacts.
WinAmp and lame have no problem whatsoever with the corresponding mp3 files, so I guess itīs a problem with the xaudio engine. Do I remember right that 1.1 is going to use a different decoder engine?
I am able to send one or two of the mp3s in question to anyone that is interested in debugging this / trying to reproduce this behavior.
cu,
sven
#20678 - 18/10/2000 05:38 Re: random decoding errors? [Re: smu]
schofiel
It ight be worth carrying out a memory check on your machine with the CTRL-T trick, just to eliminate a RAM fault.
#20679 - 18/10/2000 09:25 Re: random decoding errors? [Re: smu]
This behavior should never happen. Contact support@empeg.com, you might have faulty RAM or a hard disk problem.
#20680 - 18/10/2000 12:45 Re: random decoding errors? [Re: smu]
Smoker_Man
Loc: Calgary, CANADA
Same problem here.
However, the memory test did not resolve the memory issue (no errors reported), as mine would reboot with the new ver , and then go on playing. (it also took mine 5 minutes to boot up, and the audio artifacts would actually cause my unit to hang, and not reboot. All after about 30 minutes of playtime.)
So regardless, my unit is currently flying over the pond (as of this post), back to its origins, to get repaired.
I only hope I don't have to wait too long!
2x160Gb MkII Lighted Buttons 080000449
#20681 - 18/10/2000 13:06 Re: random decoding errors? [Re: Smoker_Man]
EngelenH
Loc: Belgium/Holland
I think you will find the empeg-techies to perform ... far above average ... As you will no doubt find out browsing this forum.
Hans.
Mk2 - Blue - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#20682 - 20/10/2000 08:09 Re: random decoding errors? [Re: schofiel]
smu
Just to make Robīs posting a bit more complete: What that CTRL-T trick is about can be found here.
cu,
sven
