#226008 - 07/07/2004 15:22 Web log analyzer for 500 errors
trs24
So we have been having some internal server errors that are showing up in our WebTrends logs. However, the WebTrends reports only tell me how many errors have happened and at what time. They don't tell me any useful info like what page threw the error and what the referrer to that page was, etc...
Does anyone here know of a tool that can provide more info about 500 errors on the web server from the logs? The logs are from IIS on a W2K server. I imagine the logs themselves provide more info than what WebTrends is telling me - or am I wrong?
Thanks for any help!
- trs
#226009 - 07/07/2004 15:24 Re: Web log analyzer for 500 errors [Re: trs24]
Nope, access logs typically don't tell you what went wrong. You need to dig into the error logs for that. The error logs are generally in the same directory as the access logs, but I don't know IIS well enough to tell you where to look exactly.
#226010 - 07/07/2004 15:35 Re: Web log analyzer for 500 errors [Re: trs24]
Does IIS put any of those errors in the operating system's event logs? Have you looked there?
#226011 - 07/07/2004 16:58 Re: Web log analyzer for 500 errors [Re: tfabris]
trs24
Yeah, I've looked there. 500 errors, though don't seem to be loged as an event. I can't find any place where error logs are written from IIS. Humpf.
I think I'll just have to go through the logs manually and search for the 500 errors and see what I can gather from there. Gotta love MS.
- trs
#226012 - 07/07/2004 17:49 Re: Web log analyzer for 500 errors [Re: trs24]
All you get is what's in C:\WINDOWS\System32\LogFiles\W3SVC1. Other than that, you're SOL.
#226013 - 07/07/2004 23:02 Re: Web log analyzer for 500 errors [Re: trs24]
g_attrill
Loc: Hants, UK
If there is a way then I would be interested.
I have some ASP page that just dumps the properties of the error out to a text file. You just need to set it as the Custom Error page for 500.100 errors.
Thinking about it, it might be possible to append the W3 log file, but I suspect it would be locked by the IIS process. You might be able to get to it using an ISAPI filter, but that is a bit beyond me.
edit: Here's some example code for getting error properties from an ASP page. This is saved as something like 500.asp and set as the custom error page.
Response.Status="500 Server Error"
Response.Write("<h1>whoops we have an error!</h1>")
Set objError = Server.getLastError()
strNumber = objError.AspCode
strSource = objError.Category
strPage = objError.File
strDesc = objError.Description
strCode = Server.HTMLEncode(objError.Source)
strLine = ObjError.Line
strASPDesc = ObjError.ASPDescription
I usually log the Request.ServerVariables("HTTP_REFERER"), Request.QueryString and Now() so that it can be easily tied back to the log files if required.
Gareth
Edited by g_attrill (07/07/2004 23:07)
#226014 - 08/07/2004 14:17 Re: Web log analyzer for 500 errors [Re: g_attrill]
trs24
Ah of course!! Why didn't I think of that. Thanks Gareth... *Implementing custom 500 error page now*
- trs
#226015 - 08/07/2004 16:28 Re: Web log analyzer for 500 errors [Re: g_attrill]
trs24
Boy, what an elegant solution. I can't believe I didn't create a custom 500 page years ago!
Thx again.
Edited by trs24 (08/07/2004 21:55)
- trs
#226016 - 08/07/2004 17:23 Re: Web log analyzer for 500 errors [Re: trs24]
Does that mean I should stop hitting F5?
#226017 - 08/07/2004 17:36 Re: Web log analyzer for 500 errors [Re: trs24]
Don't check it out too many times, though, cause it emails me every time someone causes a 500 error.
Two words: web spider
#226018 - 08/07/2004 18:28 Re: Web log analyzer for 500 errors [Re: Phoenix42]
trs24
Ha ha... I knew I shouldn't even have written that.
- trs
#226019 - 08/07/2004 18:29 Re: Web log analyzer for 500 errors [Re: peter]
trs24
Luckily that is preventable.
- trs
#226020 - 08/07/2004 18:59 Re: Web log analyzer for 500 errors [Re: trs24]
g_attrill
Loc: Hants, UK
Good stuff, I have found it very useful and do the same for 404's. I log all the sites on my servers to a single folder which I check every now and then. 404's do need a bit of filtering though - things like Office Shortcut bars attempt to call a web services DLL and you get people scanning for exploitable CGI's etc, and then you have favicon's robots.txt etc.
Gareth
