#231777 - 27/08/2004 21:25 Cant sync my device
SonicSnoop
Loc: Triangle, VA
Now before I get FAQ'd I followed this proceedur(sp):
manual fsck
when ever I sync an error dialog pops up saying:
Unable to synchronize with the current device. Failed to synchronize with device. FSCK found an serious problem (check logs for explanation).
Unable to synchronize with the current device. caused by:
Failed to synchronize with device. caused by:
org.jempeg.protocol.ProtocolException: FSCK found an serious problem (check logs for explanation).
at org.jempeg.empeg.protocol.EmpegProtocolClient.fsck(EmpegProtocolClient.java:958)
at org.jempeg.empeg.protocol.EmpegProtocolClient.checkMedia(EmpegProtocolClient.java:968)
at org.jempeg.empeg.protocol.EmpegSynchronizeClient.beforeSynchronize(EmpegSynchronizeClient.java:272)
at org.jempeg.protocol.AbstractSynchronizeClient.synchronize(AbstractSynchronizeClient.java:220)
at org.jempeg.manager.SynchronizeUI.synchronize(SynchronizeUI.java:109)
at org.jempeg.manager.SynchronizeUI$1.run(SynchronizeUI.java:65)
at java.lang.Thread.run(Unknown Source)
Is there another entry in the FAQ I may have missed? I swear I did search thru What log file is it refering too? if there is any more info you need from me please let me know. Thanks!
#231778 - 27/08/2004 21:46 Re: Cant sync my device [Re: SonicSnoop]
You had the right FAQ entry. There's nothing else to point you towards, you were in the right place.
So did you get any error messages when you did that FSCK? Perhaps do it again, this time, capture the terminal output to a file as you do it.
#231779 - 27/08/2004 22:38 Re: Cant sync my device [Re: tfabris]
SonicSnoop
Loc: Triangle, VA
Ok I have run it like 5 times now, the last time I have captured the logs as you requested and here is what I got:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v410 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Wed Aug 4 00:27:49 EDT 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 40103286) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004f00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: IC25N030ATDA04-0, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: IC25N030ATDA04-0, 28615MB w/1806kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:d6
Partition check:
hdb: [PTBL] [3876/240/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
VFS: Mounted root (ext2 filesystem) readonly.
change_root: old root has d_count
empeg init 0.8
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
opening display...
empacman running as pid 17
emphatic v2.04 (built Aug 17 2004 21:05:49) running as pid 12
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 124 (adjustment 10)
Vcb: 0x407cd000
hijack: removed menu entry: "<NULL>"
q
Restored terminal settings
Player exited normally:
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted. Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1604/4096 files (0.9% non-contiguous), 16323/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted. Pass 1: Checking inodes, blocks, and sizes
/dev/hda4: 5324/228352 files (2.8% non-contiguous), 1966171/7304850 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted. Pass 1: Checking inodes, blocks, and sizes
/dev/hdc4: 5536/228160 files (15.9% non-contiguous), 7851614/29204280 blocks
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
#231780 - 27/08/2004 22:40 Re: Cant sync my device [Re: tfabris]
SonicSnoop
Loc: Triangle, VA
newguy1 pointed out a part of that FAQ I overlooked which fixed my problem. I had to turn off emphatic before syncing. Thanks!
Edited by SonicSnoop (28/08/2004 02:59)
