#252587 - 25/03/2005 02:39 RoadMap GpsApp Route Help
BaBa
Loc: Ventura, CA USA
I just installed RoadMap GpsApp today - works great!
My problem is getting the route feature to work. I converted mapsonus.com data using GPS Utility - no luck.
I've spent a couple of hours looking for the MapsOnUs python conversion script - no luck
Will GPS Utility conversion of MapsOnUs work with GPSApp?
Where can I find the MapsOnUs conversion python script?
GPS Utility conversion attached
Edited by BaBa (25/03/2005 03:39)
#252588 - 25/03/2005 02:53 Re: RoadMap GpsApp Route Help [Re: BaBa]
It's part of the distribution file of GPSapp, if I recall correctly. In other words, it's inside the zip/tar/whateveritis.
Remember that you need an actual python interpreter program installed on your system. You have to feed the python script AND The parameter of the saved map data from MapsOnUs to the python interpreter program.
I'm pretty sure that the GPSapp readme gives pretty clear instructions on how to do all of this.
Finally, keep in mind that the Roadmap feature and the GPSapp routing feature are separate things and don't work well when used at the same time (the scale doesn't match).
#252589 - 25/03/2005 03:37 Re: RoadMap GpsApp Route Help [Re: tfabris]
BaBa
It works!!!!
Thank you! Thank you! Thank you! FAQ MASTER!
You da man!!
#252590 - 25/03/2005 15:34 Re: RoadMap GpsApp Route Help [Re: BaBa]
Cool, glad you're in business.
