#277624 - 14/03/2006 11:26 Tuners
n2toh
Loc: New Jersey, United States
Can any of the tuner modules cover the Japanese 76-90MHz FM band?
This would be quite useful for people in North America to listen to audio on Television Channels.
CH 6 audio is on 87.75 MHz
CH 5 is on 81.75 MHz
CH 4 is on 71.75 MHz
CH 3 is on 65.75MHz
CH 2 is on 59.75 MHz
108 to 138MHz is used for aircraft navigation and NOAA Weather transmissions.
CH 7 at 179.75 MHz is pushing it.
Edited by n2toh (14/03/2006 12:08)
The only difference between science fiction and reality is about 60 years.
100GB MK2 Green 080000171 + OEM tuner
v3.00a11 hijack v450 jEmpload v70
#277625 - 14/03/2006 22:55 Re: Tuners [Re: n2toh]
For FM mode, the bottom end is 87.9Mhz (or maybe 87.5Mhz), and the top side is 107.5Mhz (or possibly 108Mhz)..
Some of the PCATS modules *may* have "weatherband" capability, at 162.475Mhz. There is also a microscopic chance that some of these may also have Japanese FM capability (part numbers 3x0194, 3x0195).
#277626 - 14/03/2006 23:20 Re: Tuners [Re: mlord]
n2toh
where is the part number listed? with my luck it's inside the enclosure. and my tuner is velcroed to the inside of my dash. if any of the hardware can support out of band operation how does someone tune to the non broadcast frequencies? at this point it almost seems like it would be easier to hack a scanner in place of a tuner module.
#277627 - 15/03/2006 06:34 Re: Tuners [Re: mlord]
FM band goes to at least 107.9MHz. We have a station here that's 107.7MHz
#277628 - 17/03/2006 13:16 Re: Tuners [Re: n2toh]
Aircraft are AM.
