#312858 - 11/08/2008 14:52
Buttons stopped working
I have a problem with my empeg Mk 2 player.
Firmware: 3.00-alpha11 hijack 471
When I boot it, it seems ok, and everything shows ok on the screen, but after it go blank, and the little blue diode starts to blink, it won't react to anything, either pushing any of the buttons or using the remote. So I can't turn it on, neither in my car or at home.
When I put the usb cable in a computer, the computer finds the device, and it's possible to install the usb driver, but emplode doesn't find it.
Any idea what the problem could be and if there's something I could do myself to fix it?
#312866 - 11/08/2008 16:26
Re: Buttons stopped working
[Re: jesper]
I have a problem with my empeg Mk 2 player. Post a serial log.
#312883 - 12/08/2008 03:14
[Re: Roger]
Here's the serial log when I boot, I guess you where meaning this:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v471 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Apr 27 21:31:57 EDT 2007 Processor: Intel StrongARM-1100 re Checking for extra DRAM: c1000000: wrote ffffffff, read e28cc001 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30102736) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Tuner: loopback=0, ID=-1 show_message("Hijack v471 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005e80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks o empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0x0080 ide_data_test: wrote 0xffff read 0x0080 ide_data_test: wrote 0xaaaa read 0x0080 ide_data_test: wrote 0x5555 read 0x0080 ide_data_test: wrote 0x0000 read 0x0080 ide_data_test: wrote 0xffff read 0x0080 ide_data_test: wrote 0xaaaa read 0x0080 ide_data_test: wrote 0x5555 read 0x0080 ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x55 hda: IBM-DJSA-210, ATA DISK drive ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: IBM-DJSA-210, ATA DISK drive ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: IBM-DJSA-210, ATA DISK drive ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: IBM-DJSA-210, ATA DISK drive ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: IBM-DJSA-210, ATA DISK drive ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: IBM-DJSA-210, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:b 0 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000
#316743 - 28/11/2008 09:10
[Re: jesper]
My empeg shows exactly the same behaviour.
Boot-Log:
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue Sep 4 09:18:20 EDT 2007 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e28cc001 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 120001072) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99b78 Tuner: loopback=0, ID=-1 show_message("Hijack v479 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004700). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0xff80 ide_data_test: wrote 0xffff read 0xff80 ide_data_test: wrote 0xaaaa read 0xab80 ide_data_test: wrote 0x5555 read 0x5580 ide_data_test: wrote 0x0000 read 0xff80 ide_data_test: wrote 0xffff read 0xff80 ide_data_test: wrote 0xaaaa read 0xab80 ide_data_test: wrote 0x5555 read 0x5580 ide_data_test: wrote 0x0000 read 0xffbf ide_data_test: wrote 0xffff read 0xffbf ide_data_test: wrote 0xaaaa read 0xffbf ide_data_test: wrote 0x5555 read 0xffbf hda: TOSHIBA MK6021GAS, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: TOSHIBA MK6021GAS, 57231MB w/0kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:30 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: CET Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 Using non-standard cache size 90 (bonus 0Mb, adjustment 10) player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4069a000
--------- Thanks, Peter
#316745 - 28/11/2008 09:31
[Re: spag]
My empeg shows exactly the same behaviour. CTRL-C the player and restarting it without playlist ("player -i") on the serial console seems to help. Thanks, Peter.
#316768 - 29/11/2008 04:26
[Re: spag]
Check for a pinched displayboard ribbon cable.
#321429 - 15/04/2009 14:52
[Re: spag]
My empeg shows exactly the same behaviour. CTRL-C the player and restarting it without playlist ("player -i") on the serial console seems to help. Thanks, Peter. Well, it worked for me too! What does it do, and what was the problem to begin with?? Everything seems normal now? Great!
#321430 - 15/04/2009 15:19
[Re: jesper]
CTRL-C the player and restarting it without playlist ("player -i") on the serial console seems to help. Well, it worked for me too! What does it do, and what was the problem to begin with?? If player -i fixed your problem, then it means the player was frozen because it was trying to play a corrupted MP3 file, and it's liable to freeze again the next time it hits that file. If you can find out which file it is, you should delete it.
#321451 - 16/04/2009 02:33
Doesn't necessarily have to be an mp3 file. I've forgotten how it did it but one time I managed to load something that wasn't an mp3. Didn't even have .mp3 in the file name, but it stopped the player cold.
