#373084 - 01/10/2020 09:45 Tuner Issues
johnjore
Hi all!
For a variety of reasons, I've dug my Mark 2 Empeg out of storage and installed it in a 20 year old Toyota Starlet.
MP3's play without issue, AUX input is connected to an external DAB (Australian MonkeyBoard) and works fine.
Problem is the Tuner. I can see the tuner, and I can search and change frequencies, but no signal / audio. I've tried 2x antennas, and they work with the old radio in the car, so pretty sure its a problem with the Tuner. All cables look ok, with good connections etc.
Any ideas?
John
#373085 - 01/10/2020 12:16 Re: Tuner Issues [Re: johnjore]
If it's a "factory tuner" (little black box) then perhaps it has died. Quite a few of them just seem to stop working for no obvious reason, and we've never put enough effort into discovering exactly what in them fails -- it's something inside the protective RF metal "can" on the PCB. Probably an op-amp.
That may not be the issue in your case, or it may be.
Another common failure is the 90-degree antenna connector -- you can probably just pull it out (it plugs into the tuner) to inspect it.
#373086 - 02/10/2020 01:22 Re: Tuner Issues [Re: johnjore]
johnjore
Hi and yes, its the factory tuner.
Thanks for the suggestion, I'll try pulling the antenna connector apart, can't get much worse as its not working.
John
