#45771 - 09/11/2001 04:22
Mark I kernal image?
Loc: Pompano Beach, Florida
I don't have Linux and was wondering if there was someone that could put these wonderful hacks together for me for my Mark I with two drives using Kim Covil's setpowersource (mine can't tell if it's in the car or not), Mlord's Hijack v41 (47 doesn't work on mine) menu kernel & Frank's IR Trans patch all for the 2.03b Upgrade?
Is this even possible to put them all together?
Steve
#45772 - 10/11/2001 00:10
Re: Mark I kernal image?
[Re: DarkStorm]
Loc: San Carlos, CA
I am not sure about the setpowersource, but the rest of it is definately combinable. I will try to build you one tomorrow with everything if someone does not beat me to it. Send me a private message if I forget.
-Mike
Edited by mcomb (10/11/2001 00:11)
#45773 - 10/11/2001 16:06
[Re: mcomb]
Loc: San Carlos, CA
Do you still want this? Sounds like mlord (aka Da Man) may have already taken care of you in another thread.
-Mike
#45774 - 10/11/2001 16:29
[Re: mcomb]
I don't know he still hasn't said anything about putting in the IR hack in for me yet.
I have a question though. With the IR hack can I set it up to use more than one remote because I have 2 others that the Empeg can see the codes on and I want to use all 3, that way I can use 1 at home, 1 for in the car & 1 for at work.
If not then I would need a hijack kernel for all three depending on which I want to use at the time.
#45775 - 10/11/2001 19:52
[Re: DarkStorm]
I haven't tried building a mkI kernel... but I assume it is just a matter of taking the car1 .config and compiling... I can do that for you if someone can get me a patch for Frank's IR trans against v2.00b3...
As for using setpowersource... what do you want to use to test for being in-car...? The setpowersource code itself should work fine... I am not sure when to call it on a Mk1... I use the presence of a tuner for my Mk2... but I don't think this will work with a Mk1... I can make a kernel image for you that will always think it is in the car...? I am thinking of trying to tie it it some buttons being held down on boot, but haven't started looking at that yet...
If we can work out something to test for when your mk1 empeg is in the car I might be able to put together an upgrade file for you...
Kim
#45776 - 10/11/2001 23:28
[Re: DarkStorm]
Loc: San Carlos, CA
OK, give this one a try. It is hijack v55 + irhack for MK1 2.0b3. I have not tested it since I don't have a MK1.
-Mike
#45777 - 11/11/2001 00:58
[Re: kimbotha]
I am very interested in knowing exactly how you have customized your IR setup. What files did you modify, where did you place them (and how?) etc.. or is the built-in IR stuff in the IR hack all that you need (no external IR translation tables) ??
Just trying to understand how this stuff works (today).
{ Oooh Ahhhh... now it says I'm an enthusiast.. }
Edited by mlord (11/11/2001 00:59)
#45778 - 11/11/2001 11:32
[Re: mcomb]
Ok, It works but how do I set it up with a table to remap my other remotes. I tried the instructions on Franks site and when it went to reboot, in the serial output tells me when it gets to the init.empeg that bash says "No" and then the unit locks.
What am I doing wrong?
Steve
#45779 - 11/11/2001 12:06
[Re: DarkStorm]
Loc: San Carlos, CA
Umm, I haven't done the remap table in a long time since my remotes codes are in there as the defaults. What does your remap table look like? Show us that and the serial output and maybe someone will have an idea.
-Mike
#45780 - 11/11/2001 13:13
[Re: mcomb]
Ok, I tried it again and it doesn't lock anymore but my mapping doesnt work and it seems to not want to remount as read only
This is the output on the serial port & my installation.
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# rw
empeg:/empeg/bin# cd /sbin
empeg:/sbin#
empeg:/sbin# mv empeg_ircodes /etc
empeg:/sbin# mv init init.empeg
empeg:/sbin# mv init.ir_trans init
empeg:/sbin# chmod +x init
empeg:/sbin# ro
mount: / is busy
empeg:/sbin# ro
mount: / is busy
empeg:/sbin# cd /empeg/bin
empeg:/empeg/bin# ro
mount: / is busy
empeg:/empeg/bin# exit
logout
Shell exit
Starting player
empeg-car 2.00-beta3 2001/10/17.
Prolux 4 empeg car - 1.860 Oct 17 2001
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 239332, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 239332, error=0xc0044000
q
Starting bash.
mount: / is busy
logout
Shell exit
Starting player
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 430716, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 430716, error=0xc0044000
This is my empeg_ircodes file
# Do not remove this line. It is needed by kernel. Syntax: :
0x00b9460a:0x00ad5211
0x00b9460b:0x00ad5212
0x00b9460c:0x00ad521c
0x00b9460d:0x00ad521e
0x00b9461b:0x00ad5214
0x00b9460f:0x00ad5212
0x00b9465e:0x00ad5217
0x00b9460e:0x00ad520c
0x00b94615:0x00ad520b
0x00b94614:0x00ad520a
And this is the init.ir_trans I used.
#!/bin/bash
mount -n -o remount,ro /
cat /etc/empeg_ircodes > /dev/ir
exec /sbin/init.empeg
What did I do wrong?
Steve
#45781 - 11/11/2001 13:19
[Re: mcomb]
Is there anyway the remap tables could be put into the config.ini instead?
Man, I really need to start learning this Linux stuff. I feel outdated compared to you guys.
steve
#45782 - 11/11/2001 17:26
[Re: DarkStorm]
Loc: San Carlos, CA
Hmmm, I am concerned about the lines that say...
empeg:/sbin# ro
mount: / is busy
Something is running from the drives and it did not properly mount them read only. This may mean that the files you added (ir init, and ir map file) never got written out to disk. Connect to the empeg again and make sure they are actually there. Also, post a full boot log (connect with terminal program and then plug in empeg power). IIRC frank's stuff prints out all of the remappings when the empeg boots.
You may want to just try adding the files again to see if you can get it to work without that error.
-Mike
#45783 - 11/11/2001 17:29
[Re: DarkStorm]
Loc: San Carlos, CA
Frank would have to setup his stuff to read from that file. I don't know if he has any plans to do that.
-Mike
#45784 - 11/11/2001 17:54
[Re: mcomb]
I was incorrect. Upon doing a cold reboot I find that it is still locking up.
This is what comes through....
empeg-car v0.04 19990121 (altman@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux......................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50 (mcomb@grovepc) (gcc version 2.95.2 19991024 (release)) #7 Sat Nov 10 22:06:57 PST 2001
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00102)
Command line: mem=8m
Memory: 7296k/8M available (600k code, 20k reserved, 272k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
AD520B->B94615 11358731->12142101
AD520A->B94614 11358730->12142100
AD5242->B9460A 11358786->12142090
AD5243->B9460B 11358787->12142091
AD5212->B9461B 11358738->12142107
AD521A->B9461F 11358746->12142111
AD520C->B9460E 11358732->12142094
AD5240->B9460D 11358784->12142093
AD5241->B9460C 11358785->12142092
AD521E->B9465E 11358750->12142174
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005380).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: IBM-DJSA-230, ATA DISK drive
hdc: IBM-DARA-218000, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
ide1 at 0x000-0x007,0x038 on irq 6
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdc: IBM-DARA-218000, 17297MB w/418kB Cache, CHS=37488/15/63
Partition check:
hdc: hdc1 < hdc5 hdc6 > hdc2 hdc3 hdc4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
Also why is naming the drives "hda" and "hdc" instead of
"hda" and "hdb" ?
#45785 - 11/11/2001 18:46
[Re: DarkStorm]
Loc: San Carlos, CA
OK, try this one. I rebuilt my kernel source to make sure all of the MK2 bits and other patches are out. All this one is is 2.0b3 MK1 with irhack. If you can get this to work than I will patch hijack in also and we can see if that works.
The reason the drives show up as hda and hdc is because the MK1 has two ide channels with the two drives as the masters on each channel. hdb would be the slave on the first channel.
-Mike
#45786 - 11/11/2001 19:58
Hijack v57 & config.ini
[Re: mcomb]
Just before I disappear, I figured I might make that easier for someone (Frank?) to do.
Hijack v57 is now out, and includes a read of config.ini during boot-up. It doesn't actually do anything with the file other than read it, mostly cuz I haven't had time to do more than figure out the reading part. But if we can agree on a nice, compact, extensible format for specifying MULTIPLE sets of IR data in this file, then we can very simply have the Hijack menu extended to select among codesets.
Maybe someone will cobble it together while I'm away for the next 5 weeks.
Edited by mlord (11/11/2001 20:03)
#45787 - 11/11/2001 22:56
[Re: mcomb]
Ok. What is apparently happening is my Pioneer remote still isn't working except for a couple of buttons that happen to have the same code that you compiled into the kernel.
I rebuilt the player and captured the output for each stage.
Followed Franks instructions again but the time I also added his enabling of the verbose ir output on the serial port.
This is the capture just after the IR only kernel was installed....
e000 v1.04
Copying kernel...
Uncompressing Linux........................ done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg49 (mcomb@grovepc) (gcc version 2.95.2 19991024 (release)) #2 Sun Nov 11 17:27:32 PST 2001
Memory: 7316k/8M available (584k code, 20k reserved, 268k data, 4k init)
empeg state support initialised 0089/8893 (save to d0005900).
Partition check:
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To CompStarting player
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 2425870, error=0xc0044000
And this is the capture after I installed the map file and new init.
e000 v1.04
Copying kernel...
empeg state support initialised 0089/8893 (save to d0005980).
Partition check:
Mounting proc
Starting player
Vcb: 0x402be000
E !! mp3_decoder.cpp 1052: Failed to seek to offset 829747, error=0xc0044000
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offset 829747, error=0xc0044000
And this is what it is showing with the verbose reporting...
AD520A -> B94614
AD520A -> not sent
80AD520A -> 80B94614
AD520B -> B94615
AD520B -> not sent
80AD520B -> 80B94615
AD5210 -> AD5210
AD5210 -> AD5210
AD5210 -> AD5210
80AD5210 -> 80AD5210
AD5211 -> AD5211
AD5211 -> AD5211
AD5211 -> AD5211
80AD5211 -> 80AD5211
4 button presses.
Vol +
Vol -
Track +
Track -
The volume happens to be the same codes as my remote but the track buttons aren't.
Apparently it's not reading the ircodes file, maybe because there were already codes compiled in the kernel?
Any ideas?
#45788 - 12/11/2001 00:23
[Re: DarkStorm]
Loc: San Carlos, CA
Yeah, your init is not working, the map file is not getting cat'd to /dev/ir, or it is not getting recognized. Did you make sure that your modified init is actually on the player? Connect with terminal program and type
cat /sbin/init
and make sure it looks like what you posted above. Frank V, are you around? Does he have this setup correctly?
-Mike
#45789 - 12/11/2001 12:18
Re: Hijack v57 & config.ini
Loc: San Jose, CA
Before you go, did you know there's a bug in 52 that prevents the Fader controls from popping up?
Calvin
#45790 - 12/11/2001 12:28
[Re: eternalsun]
No, I didn't know that.
where do they normally pop up? and how is it broken?
#45791 - 12/11/2001 12:38
Loc: San Jose, CA
Well, you push the knob to access the menus. The first push gets you the voladj setting, then you keep pushing it, eventually you get the fader setting... however, when the fader setting pops up, the voladj thing pops up on top of that (hijacked!)... You don't get the fader slider on the 'home" setting but only in the "car" setting. So the voladj push button hijack hack works fine at home, but in the car you lose the fader settings.
Calvin
#45792 - 12/11/2001 12:48
[Re: eternalsun]
The reason this is happening is because you have applied his 2.0b3 kernel atop your 2.0b5 interim alpha-team build.
Mark is not on the alpha team and is therefore unaware that the behavior of the sound options is changing (fader is removed from home mode cycle).
This is a nice heads-up for Mark for when the next public release of the 2.0 code happens, though. I hope somebody's ready to tweak his kernel as new betas are released while he's away this month.
#45793 - 12/11/2001 12:58
Actually, I just played with it now (v200b3) and it's broken there, too. Hijack doesn't really care about the lack of a fader pop-up, it's just that it pops up so quickly the hijack code "misses it" (I know, that sounds funny..)
I'm working on it now..
#45795 - 12/11/2001 13:28
Okay, the Fader pop-up now reappears in v61.
A side-effect of fixing it, is that the VolAdj now only appears once, at the start of the knob-press cycle.. repeated presses will cycle among the sound adjustments, but to see VolAdj again one must wait for the pop-ups to disappear before pressing the knob again.
Sounds way more complex than reality.
#45796 - 12/11/2001 13:57
Loc: San Jose, CA
I'm not on the alpha team. Whew, thought I was going to have to go on the run from the Mob for a minute there.
Calvin
