#77129 - 02/03/2002 10:46 Starting audio... baaaaaah!
Narin
I have been stricken with the "starting audio..." lockup. every now and then (and almost every time I switch to AUX-IN), the player will crash, and when it reboots it crashes again on "starting audio..." and takes a lot of restarts to get it back.
I saw a couple other threads about this, but they all kind of died...
I emailed support, and they said to downgrade to 1.03 and try it, and hey, that fixed it, but now I don't get all the features of 2.0b11...
I don't think support will fix it unless it happens under 1.03.
I suspect it may have something to do with polling the aux-in to render visuals...I tried turning off visuals but no help...what else can I do!!
-nick
Nick Farina -- [blue]Blue 10gb Mk2[/blue]
#77130 - 02/03/2002 11:34 Re: Starting audio... baaaaaah! [Re: Narin]
justinlarsen
Loc: Petaluma, CA
did you try upgrading now that you downgraded you might hvae had a bad kernal before hand
---- Justin Larsen
#77131 - 02/03/2002 11:42 Re: Starting audio... baaaaaah! [Re: Narin]
Folsom
Loc: Atlanta
I had this same problem when I was switching from the player to the tuner. If the time showed "12:00", then switching to tuner would lock it up, although Hijack seemed to work. It would take up to 10-15 restarts to get the player to work. I assumed it was a clock issue since the time would reset overnight, but the clock resetting may just be a symptom of a different problem.
I could not get it to lockup using the AC adapter. My problem only happened in the car. My spare player does not show this problem in the same sleeve. Also, I switched tuners just in case it was a bad tuner, but this did not solve the lockups.
I sent the player in to support to fix the clock. Support could not find a problem with my clock, but they swapped empegs anyway. Hopefully when I get it back the lockups go away, otherwise I can't use the tuner.
#77132 - 02/03/2002 13:02 Re: Starting audio... baaaaaah! [Re: Narin]
Happy Birthday JrFaust
Loc: New Richmond, WI
My Rio was doing that and I ended up going back to 1.03 no Hijack then I put on the dev 2.00b11 and the latest Hijack then the problem was gone, but I edited my config.ini so I can't go into aux mode (I don't use aux mode).
[ir_translate]
20DF03.L=Top.L,null ;Long press goto standby
20DF03.T=Player ;If in tuner change to main
20DF03.M=Top.L,null ;If in main goto standby
The code (20DF03) is for the Rio remote source botton.
Hope this helps.
Drive fast, Play it loud!!!
20GB Original Blue Lens MKIIa Rio SN 030102760, Blue Buttons.
20GB Original Green Lens MKIIa Rio SN 040103268 Grey Buttons.
#77133 - 02/03/2002 14:48 Re: Starting audio... baaaaaah! [Re: Narin]
My Rio started doing this, and I had to send it back. Look at your RIo when starting up and see if your get an error:
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
as you can see my player couldn't find the Aux-In chip. Needless to say, it's now actually a different player.
