#8195 - 19/05/2000 16:53 adding hard drives
Anonymous
Unregistered
I have just purchased a 6 gig used empeg I want to know how difficult it is and what type of hard drive to use to upgrade. I have also misplaced my emplode disc, any hackers out there that will tell me where to go to get a copy ? Thanks for the help. sneekerzz@aol.com
#8196 - 19/05/2000 17:02 Re: adding hard drives
You can get upgrades of both Emplode and the Empeg Car firmware at http://www2.empeg.com/upgrades/. Be sure to get the latest ones of both.
Adding a hard disk is easy, if you're careful. Check out http://www.dmoore.com for step-by-step instructions. The only tough part about adding the second hard disk is getting the correct IDE cable. It needs to be a specific type of a certain length since there's no room in the case to fold a too-long cable.
Tony Fabris (http://www.jps.net/tfabris)
Empeg #144
#8197 - 19/05/2000 17:07 Re: adding hard drives [Re: tfabris]
Whoops! Forgot to mention a few things:
1) Congratulations on your new Empeg!
2) The type of hard drive supported is: Any IDE laptop drive will do, but it must be no taller than 12.5mm. There is very little remaining space in the Empeg case.
3) Register and log in to this BBS instead of posting anonymously. There are some great discussions going on and there is a good community here. Join us!
Empeg #144
