#85002 - 02/04/2002 19:03 hijack / serial connection / timing question.
corrumpu
I am using minicom under FreeBSD (also tried win2k hyperterminal) and since installing hijack I cannot get to the bash prompt. I see the dmesg info @ startup but I am unable to hit q.. it says you have 0 seconds to hit q and goes right by it.. How do I get this or change the delay for the prompt??
please help
::chris
#85003 - 02/04/2002 19:48 Re: hijack / serial connection / timing question. [Re: corrumpu]
The 0 seconds is a joke, you don't have to have a delayed prompt.
You have to press Enter after you press Q, but you can do it at any time after the player software starts.
I know you don't use Hyperterminal, but the settings and troubleshooting steps quoted here still apply: click here.
#85004 - 10/04/2002 17:20 Re: hijack / serial connection / timing question. [Re: tfabris]
Waterman981
Loc: Salt Lake City, UT
Ok, I have the same problem. I have been trying to figure out why I can't change my custom animation again. I have done everything up to re-building the HD. I figured it out today and found this thread. When I am in 1.03 I can log on through Hyperterminal (XP) and get the bash. When I have 2.0b11, I can get the bash. Once I install hijack, I can't get anything. I was able to upload animations with hijack 242, but nothing since 247. What could be the deal. Also when upgrading hijack, since jEmplode can't autodetect it for some reason, I get error 16 using Tony's Logo Editor, but cycling the power I can upload a new version of hijack fine. Here is a serial dump from boot:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v253 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Tue Apr 2 09:58:14 EST 2002
25600001,
empeg-car player (hardware revision 9, serial number 30103051)r NET4.0
Writing superblocks
Command line: mem=16m
IP
TCP: Hash tables con
Memory: 14984k/16M available (1012k code, 20k reserved, 364k data, 4k init)
empeg dsp audio initialised Read a button press
Dentry hash table entries: 2048 (order 2, 16k)sp mixer initialised
Buffer cache hash table entries: 16384 (order 4, 64k)press
empeg audio-in
Page cache hash table entries: 4096 (order 2, 16k)ead a button press
empeg remote contr
Linux NET4.0 for Linux 2.2.cpp 194 ( 19)
Starting kswapd v 1.5stress.cpp 189 (
empeg single channel IDE
Prob
hda: FUJITSU MHL2300AT, ATA DIS
Signature is 20706d65 'emp 'lman (erik@vt.edu)
Found custom animation at offset 0x9bb88
b
Partition check:
empeg display initialised.da2 hda3 hda4
empeg dsp audio initialisedAMDISK: ext2 filesystem fou
empeg dsp mixer initialised
empeg dsp initialisedlocks [1 disk] into r
VFS: Mounted root (
empeg-pump v0.03 (19980601)
empeg usb initialised, PDIUSBD12 id 1012p...VFS: Mounted root (ext2 filesystem)
empeg state support initialised 0089/88c1 (save to d0005f00).
change_root: old root has d_countempeg
empeg RDS driver initialised
I
empeg power-pic dri
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu) music partition read-only
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e
Mounting proc
No secondary hard disk
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
After this point, I can do nothing. Hitting q and enter, nothing happens. I can go down to no hijack for file transfers, but no FTP with hijack, and I can't get Tony's Risky Tux off my Empeg! Please help me!!!!
BTW previous trying to correct the error: here
-Mike
Edited by waterman981 (10/04/2002 17:37)
-Michael
#040103696 on a shelf
#85005 - 10/04/2002 22:06 Re: hijack / serial connection / timing question. [Re: Waterman981]
This boot log is kinda corrupted. Have a read through it. There are blank lines where there shouldn't be and missing characters/sections.
Flow control etc? Have you changed to 115200 in config.ini. Perhaps something is wrong with your PC?
#85006 - 11/04/2002 12:22 Re: hijack / serial connection / timing question. [Re: Shonky]
Waterman981
I have everything set right. Like I said, with any kernel version, when I do not have Hijack installed, I can quit the the shell in hyperterminal. It's after I install Hijack. I tried to do that even with 240 (the oldest version I have backuped), and I couldn't access the shell. I got a serial log with 2.00b11, and no hijack and got some interesting things. I've just attached it rather than posting it. I'm wondering if where the kernel/hijack resides in the flash is corrupted somehow. Is there a way I can totally clear the flash, then reinstall the kernel? I ran the builder in the past, downgraded clear down to 1.02, 1.03, 2.00b11, and I always have Tony's risky tux. Shouldn't that be gone from flashing the kernel? That and my hijack settings stay. So I think I need to totally clear them out of memory to get things to work. Well It's something I haven't tried yet. So how would I clear the flash, or is that a no-no?
-Mike
85219-serial.txt (217 downloads)
-Michael
#85007 - 11/04/2002 12:26 Re: hijack / serial connection / timing question. [Re: Shonky]
Waterman981
Oh yeah, I don't think its my computer due to the fact that I can access the player via ethernet from any computer on the network (except FTP, and HTTP.... emplode and jEmplode only) I haven't tried serial on anyother computer because it works without hijack installed. How do change to 115200 in config.ini for home use. I saw how to for car use, but this is just at home, and I thought that was default. It is set up correctly in Hyperterminal.
-Mike
-Michael
