#85800 - 06/04/2002 12:36 jitters when changing eq settings
rockstar
Running the latest hijack i noticed last night that when i change my eq setings (band by band) everytime i nudge a band up or down the mp3 playing pauses, never used to do this. Normal or bug? Hijack or latest kernel fm empeg?
Wondering if anyone else has this.
#85801 - 06/04/2002 13:28 Re: jitters when changing eq settings [Re: rockstar]
visuvius
Yeah, i've noticed this too. But too me, if i change it slowly, it won't do it, but if i rotate the knob to make it jump up or down more than one position, it'll pause for just a sec, sometimes, the hourglass even comes on. Is this what you're talking about?
#85802 - 06/04/2002 14:04 Re: jitters when changing eq settings [Re: rockstar]
Is this only with Hijack?
Genixia, are you outputting debug messages on the serial port when bands get changed? Bad boy.
Possible work around: Increase the in-car serial port speed by editing the config.ini file (instructions in the FAQ).
#85803 - 06/04/2002 15:09 Re: jitters when changing eq settings [Re: tfabris]
rockstar
don't know f it is just hijack, haven't done a kernel swap yet, figured i would post here first. I will check and try advancing the speed.
#85804 - 06/04/2002 15:10 Re: jitters when changing eq settings [Re: visuvius]
rockstar
pretty much, but it happens even if i just change it one notch.
#85805 - 06/04/2002 15:36 Re: jitters when changing eq settings [Re: rockstar]
genixia
Uuhh. My bad.
Increasing the DC serial port speed may help alleviate or eliminate the issue. For those willing and able to roll their own kernels, a patch is attached that you can apply to hijack253 that should eliminate the problem.
me@here kernels$ls
hijack253
fixeq.patch
me@here kernels$ cd hijack253
me@here hijack253$ patch -p1 <../fixeq.patch
patching file arch/arm/special/hijack.c
me@here hijack253$ make dep && make zImage
Otherwise give me a few minutes and I'll get a binary together.
84218-fixeq.patch (220 downloads)
#85806 - 06/04/2002 16:11 Re: jitters when changing eq settings [Re: genixia]
genixia
Try hijack253-eq_stutter_fix.zimage.
Feedback appreciated..
#85807 - 06/04/2002 17:30 Re: jitters when changing eq settings [Re: genixia]
rockstar
wow! speedy fix, thanks!
oops, looks like i can't get thru to the site right now, i will try again in a bit.
Edited by rockstar (06/04/2002 17:32)
#85808 - 10/04/2002 16:05 Re: jitters when changing eq settings [Re: genixia]
rockstar
still no luck getting that downloaded..
where are you hosting it? maybe i can put it up somewhere for you.. ah wait, my site is being moved, damnit.
anyway, let me know if you find another place to store it.
TIA
-rs
#85809 - 10/04/2002 16:49 Re: jitters when changing eq settings [Re: rockstar]
genixia
Check your firewall?
I've just dl'ed it to my work machine ok, so it's definately there...If you''re still having problems, pm me your email address and I'll email it to you.
#85810 - 10/04/2002 16:55 Re: jitters when changing eq settings [Re: genixia]
rockstar
tried from 3 diff machines, unless somehow cox has blacklisted the range..which they may have,... all the machines were on the cox.net network.
if you could mail it that would be great
digiplay@cox.net I think it has a 3-4 meg limit if you need to do a multirar.. thanks again, sorry to be such a PITA
#85811 - 10/04/2002 20:02 Re: jitters when changing eq settings [Re: rockstar]
genixia
I realised on my way home that I should check my firewall - I have a rather paranoid firewall that blocks addresses that appear as invalid or unassigned in IANAs list, but I have noticed in the past that some ISPs appear to actually be using these....Lo and behold...cox.net is on 68.1.x.x and was being blocked.
Try now!
#85812 - 11/04/2002 01:37 Re: jitters when changing eq settings [Re: genixia]
rockstar
Sure enough,t hat was it.. heh, at least you know it is working well
THanks again. I, like many, really appreciate all your work.
