#95888 - 26/05/2002 21:59 Has to be an easier way to sync new music
sendero
OK, I searched the FAQ and couldn't find the answer to this question. Hopefully I'm not blind.
I commonly add new MP3s to my loocal hard drive and occasionally want to sync up my EMPEG. The problem is that if I just drag all the files in again then the software says I'm taking up too much space, even though it has identifies most of the songs as duplicates.
So, is there an easy way to have the player sync up to only the changed or added files on my local machine?
Rio Car 30gb
2000 Boxster S, <img src="/ubbthreads/images/graemlins/cool.gif" alt="" />
#95889 - 27/05/2002 07:50 Re: Has to be an easier way to sync new music [Re: sendero]
Do you have playlists created it so you need to uncheck the option to import .m3u files otherwise the files will be loaded twice.
And if you think using this software is a pain try using the pile of crap real jukebox.
#95890 - 27/05/2002 08:33 Re: Has to be an easier way to sync new music [Re: sendero]
I just maintain a mirror on my harddrive, and use my Linux empsync script to update the players periodically. But it doesn't do anything with custom playlists yet.
